AC93 Posted November 27, 2019 Share Posted November 27, 2019 Ahoy all, I'm about to purchase a load of bits for my NA-T build and can't decide which turbo is best. Who is running the 362 or 364 SXE and what power are you making? My goal is to comfortably handle 650bhp, so I don't want the 362 if that's going to be running it in it's upper limits. 0.88 a/r single scroll will be my choice.. Car is: GE non-vvti bottom end - refreshed with ARP rod bolts/head studs, ACL bearings VVTi head TT headgasket PHR NA-T manifold Possibly getting cams and valves/springs after Xmas if funds allow... What would you recommend.. is the S362 perfectly fine or am I better off with the 364, or will it just lag? Thanks, Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted November 27, 2019 Share Posted November 27, 2019 Get the 364. Marginal difference between the two in terms of response, but you won't have to push 364 as hard to make the same power. Think Wayne made that kind of power @ 1,3 bar on his 364. Quote Link to comment Share on other sites More sharing options...
MrGRT Posted November 27, 2019 Share Posted November 27, 2019 Nothing to see, sorry Quote Link to comment Share on other sites More sharing options...
Mo Reviews Posted November 27, 2019 Share Posted November 27, 2019 Are you fixed on a BW? Quote Link to comment Share on other sites More sharing options...
AC93 Posted November 27, 2019 Author Share Posted November 27, 2019 Are you fixed on a BW? Not fixed on a BW, open to suggestions Quote Link to comment Share on other sites More sharing options...
Mo Reviews Posted November 27, 2019 Share Posted November 27, 2019 Not fixed on a BW, open to suggestions I may be persuaded to part with my Precision 6262 as I'm looking to go to a 6466... Quote Link to comment Share on other sites More sharing options...
Frank Bullitt Posted November 27, 2019 Share Posted November 27, 2019 Not fixed on a BW, open to suggestions Look at something in Garrett's GTX range. If you are looking for reliable low end and midrange power they are perfect. The top end is good but they don't pull as high as others. Quote Link to comment Share on other sites More sharing options...
AC93 Posted November 28, 2019 Author Share Posted November 28, 2019 I may be persuaded to part with my Precision 6262 as I'm looking to go to a 6466... How much would you be after? Look at something in Garrett's GTX range. If you are looking for reliable low end and midrange power they are perfect. The top end is good but they don't pull as high as others. Cheers, i'll have a look Quote Link to comment Share on other sites More sharing options...
WayneW Posted November 28, 2019 Share Posted November 28, 2019 Get the 364. Marginal difference between the two in terms of response, but you won't have to push 364 as hard to make the same power. Think Wayne made that kind of power @ 1,3 bar on his 364. Yes Indeed I'm very pleased with the BW64mm, would like to break the 700bhp barrier with proper injectors next year with the help of Mike and Lee Quote Link to comment Share on other sites More sharing options...
Mo Reviews Posted November 28, 2019 Share Posted November 28, 2019 How much would you be after? Cheers, i'll have a look Not quite sure to be honest, drop me a PM with an offer if you want to take things further... Quote Link to comment Share on other sites More sharing options...
AC93 Posted December 5, 2019 Author Share Posted December 5, 2019 So I bought the S364 just waiting for it to be delivered now.. I have a manifold lined up, but which size wastegate would people recommend? Is bigger better? I was thinking a 50mm, but will a 44mm or 46mm be more than enough? Quote Link to comment Share on other sites More sharing options...
sidewaysdan Posted December 5, 2019 Share Posted December 5, 2019 Where did you get it from mate.. was looking to change mine Quote Link to comment Share on other sites More sharing options...
AC93 Posted December 5, 2019 Author Share Posted December 5, 2019 Where did you get it from mate.. was looking to change mine The manifold or turbo? Quote Link to comment Share on other sites More sharing options...
sidewaysdan Posted December 5, 2019 Share Posted December 5, 2019 Sorry mate the turbo Quote Link to comment Share on other sites More sharing options...
AC93 Posted December 5, 2019 Author Share Posted December 5, 2019 Sorry mate the turbo Ahh, I ordered it from Whifbitz mate Quote Link to comment Share on other sites More sharing options...
sunny Posted June 1, 2020 Share Posted June 1, 2020 Is there any major difference between the .88 open and .91 twin for the s364?? Also what kinda spool time would be expected for the s364 on a built ge bottom end with 264 cams and other supporting mods? Quote Link to comment Share on other sites More sharing options...
