RZtwin Posted November 17, 2019 Share Posted November 17, 2019 I will be installing 272 BC cams, springs, retainers, keepers and of course those pesky oem seals. Still a bit confused on when I need to put motor at TDC since I am doing the "rope trick" does this matter? So would you do shimless buckets like this? Please correct if wrong. 1.Remove the oem Cams. Install BC cams over the oem shim on buckets. 2.Measure clearance. 3.Do the math. 4.Buy 24 shimless buckets with proper clearance specs from my BC cams card. Remove BC cams. 5.Do the "rope trick." 6.Remove OEM buckets,springs,retainers,keepers,seals. 7.Install oem seals, BC spring,retainers, keepers,shimless buckets, camshafts? Myself being very OCD if there's anymore to this procedure please let me know. Thank you guys;) Jay Quote Link to comment Share on other sites More sharing options...
