Rear subframe bushes - where can I get them?
Nathanj1142
First off - I literally cant find anything anywhere to do with all 4 bushes for the rear subframe. I think I’m searching for the wrong thing.
I need the 2 bushes that are on the subframe that mount directly onto the chassis at the front and the two that are in the cradle on the rear.
The only bushes I can find appear to be the cradle ones on the back where the 4 smaller bolts bolt onto the body of the car. Even if I have them mixed up - there’s still only 2 bushes so what about the other ones?
Do I just replace the 2 cradle assemblies as apposed to just the bushes?
Apologies if it’s a repeated topic just really frustrated trying to find what I need
Link: http://www.garagewhifbitz.co.uk/toyota/supra/suspension-parts/poly-bushes/super-pro-1102.html
Cheers
Nathan
The part numbers are 52205-14020 & 52205-14010 for the rear mounts and 52271-14070 for the front mounts. You can replace the rear bushes with poly or solid alternatives and there is a youtube video on someone doing that with solid bushes. You will likely need to go for an aftermarket options as these parts in genuine OEM guise were very hard to find when I was buying them in 2017. This is a link to an option for the two others.
There are pre facelift and facelift variants of the four main subframe bushes.
The facelift ones have gaps in them vs solid ones from the pre facelift.
Pre facelift parts numbers are:
52271-14070
52205-14020 (Rear RH)
52206-14010 (Rear LH)
Facelift part numbers are:
52271-14080
52205-14040 (Rear RH)
52206-14030 (Rear LH)
This link will help too.
https://www.megazip.net/zapchasti-dlya-avtomobilej/toyota/supra-38377/jza80-55401/jza80-alfqz-913594/suspension-crossmember-under-cover-17774934#
All the facelift bushes are readily available, should you be unable to source a pre facelift variant.
