LH Rear ABS Sensor
mwilkinson
LH Rear ABS Sensor
Used ABS sensor from my 1996 Supra. I bought new rear ABS sensors as part of my rebuild and the RH side broke on removal, hence only this side for sale. Was working prior to removal.
Please note there are plier marks on the side of the sensor from its removal.
This part is sold as seen. If you require further images or info please ask.
Price: £80 (inclusive of postage within the UK using a recorded service).
Edited by mwilkinson (see edit history)
If you have a multi-meter to hand you can do a simple test that would suggest if the sensor is good or not. Just check the resistance, from memory I think the spec on that is around 9k ohms. It needs to be a steady stable reading and not rise as the test progresses or be entirely absent which would suggest a broken circuit.
Seems sensible. I'll do that later today and update the thread with the results.
