Questions about behaviour Getrag V160/161
Stephen88
Hi All,
I am new to the Supra ownership and after a search on google and some chats with more experience owners, it seems is fairly normal that there is a bit of clunking noise when changing in the lower gears? Appreciate if fellow manual TT6 owners can attest to this.
Last night I was just cruising quietly on some smaller roads roadabouts etc....when I upshift from 2nd to 3rd or downshift from 3rd to 2nd there is a clunking noise and sometimes a bit of a quiet whine almost soft grind noise as the gear engages.:blink: When I put my foot on the accelerator in 3rd there is a soft clunk noise as well (after the gear change).
Just like to hear from fellow owners on this as I am new to the ownership and trying to understand if there is an issue with the car. :rolleyes:
sorry if this has been discussed before but I have tried the search functionality.
Thanks!!
Things that can wear and make it worse in time are the dual mass flywheel, transmission mount, and the shifter gate plastic.
Bushes in cabin at base of shifter can wear
http://www.mkivsupra.net/vbb/showthread.php?332597-Getrag-6-speed-(160)-struggling-to-put-in-reverse!&highlight=getrag+reverse
Transmission slack/slop (some threads from way back!)
http://www.mkivsupra.net/vbb/showthread.php?36649-How-much-slack-do-you-have-in-your-transmission&highlight=transmission+slack
http://www.mkivsupra.net/vbb/showthread.php?20377-Gearbox-Noises&highlight=transmission+slack
Edited by Scooter (see edit history)
