Bender Posted October 20, 2019 Share Posted October 20, 2019 So i was changing spark plugs in my NA and when i was taking everything apart instead of taking conector off tps i just take the screws off when i put everything back my car now stays on high revs all the time first when you start it its fine as soon you accelerate its stays on high revs. Is there any special way to put tps back on or it could be faulty car was fine before job. Any ideas Its the one on right side Wysłane z mojego SM-G950F przy użyciu Tapatalka Link to comment Share on other sites More sharing options...
jim_supra Posted October 20, 2019 Share Posted October 20, 2019 Daft question perhaps, but have you tried adjusting the position of the sensor? Loosen the two screws slightly and twist the sensor clockwise slightly and see how much difference that makes, then repeat until revs are where you want them. If I remember correctly to set it up 100% accurate you need a multimeter (may be wrong) but small adjustments to get it where you want it should be fine. Link to comment Share on other sites More sharing options...
David P Posted October 20, 2019 Share Posted October 20, 2019 How to here........... http://www.mkivsupra.net/vbb/group.php?discussionid=190&do=discuss Link to comment Share on other sites More sharing options...
Bender Posted October 20, 2019 Author Share Posted October 20, 2019 How to here........... http://www.mkivsupra.net/vbb/group.php?discussionid=190&do=discussDaft question perhaps, but have you tried adjusting the position of the sensor? Loosen the two screws slightly and twist the sensor clockwise slightly and see how much difference that makes, then repeat until revs are where you want them. If I remember correctly to set it up 100% accurate you need a multimeter (may be wrong) but small adjustments to get it where you want it should be fine.Yes i tried to adjust it revs go a bit lower but not what they should be. I also try to reset ecu by take battery off Wysłane z mojego SM-G950F przy użyciu Tapatalka Link to comment Share on other sites More sharing options...
David P Posted October 20, 2019 Share Posted October 20, 2019 Have you forgotten how to read, or did you never learn? Link to comment Share on other sites More sharing options...
Bender Posted October 20, 2019 Author Share Posted October 20, 2019 ??? Wysłane z mojego SM-G950F przy użyciu Tapatalka Link to comment Share on other sites More sharing options...
Mk4Gaz Posted October 20, 2019 Share Posted October 20, 2019 Have you forgotten how to read, or did you never learn?[emoji23] Link to comment Share on other sites More sharing options...
David P Posted October 20, 2019 Share Posted October 20, 2019 You can lead a horse to water, but you can't make it drink. Link to comment Share on other sites More sharing options...
evinX Posted October 20, 2019 Share Posted October 20, 2019 You see that white paint mark at the bottom screw, it should bascially be in alignment with the screw. Its tricky to align the TPS but doable once you see someone do it...like i remember seeing DavidP do mine Link to comment Share on other sites More sharing options...
Bender Posted October 20, 2019 Author Share Posted October 20, 2019 You see that white paint mark at the bottom screw, it should bascially be in alignment with the screw. Its tricky to align the TPS but doable once you see someone do it...like i remember seeing DavidP do mine That white paint mark ? Wysłane z mojego SM-G950F przy użyciu Tapatalka Link to comment Share on other sites More sharing options...
evinX Posted October 20, 2019 Share Posted October 20, 2019 That white paint mark ?https://uploads.tapatalk-cdn.com/20191020/3eaf281ab30fe3223c5dea3827c4efd1.jpg Wysłane z mojego SM-G950F przy użyciu Tapatalka Yep, they are put there when the sensors lined up, inline with the scews. Yours is way off, and remember it depends how you put the sensor on and if the valve inside is slightly open or not (should be closed), in the end you will find the fix was very easy Link to comment Share on other sites More sharing options...
Bender Posted October 20, 2019 Author Share Posted October 20, 2019 Yep, they are put there when the sensors lined up, inline with the scews. Yours is way off, and remember it depends how you put the sensor on and if the valve inside is slightly open or not (should be closed), in the end you will find the fix was very easyGreat thank you very much sir Wysłane z mojego SM-G950F przy użyciu Tapatalka Link to comment Share on other sites More sharing options...
David P Posted October 20, 2019 Share Posted October 20, 2019 And now you thank someone for the wrong answer! Please tell us what you think is wrong with the right answer? Link to comment Share on other sites More sharing options...
Bender Posted October 21, 2019 Author Share Posted October 21, 2019 And now you thank someone for the wrong answer! Please tell us what you think is wrong with the right answer?If i know how to do it or what is the wrong answer i wouldnt be here and asking. But yeah feel free to make a fun out of me Wysłane z mojego SM-G950F przy użyciu Tapatalka Link to comment Share on other sites More sharing options...
Frank Bullitt Posted October 21, 2019 Share Posted October 21, 2019 Did you miss this from post 3? How to here........... http://www.mkivsupra.net/vbb/group.php?discussionid=190&do=discuss Link to comment Share on other sites More sharing options...
Bender Posted October 21, 2019 Author Share Posted October 21, 2019 I didnt the problem was my taptalk dont want to open that link for some reason and i check that link later on via website Wysłane z mojego SM-G950F przy użyciu Tapatalka Link to comment Share on other sites More sharing options...
David P Posted October 21, 2019 Share Posted October 21, 2019 Is this further evidence that Crapatalk makes your brain shrink, or do only persons with shrunken brains use it? I am overwhelmed by your gratitude. Link to comment Share on other sites More sharing options...
Bender Posted October 23, 2019 Author Share Posted October 23, 2019 Is this further evidence that Crapatalk makes your brain shrink, or do only persons with shrunken brains use it? I am overwhelmed by your gratitude. You dont need to be overwhelmed its fine Wysłane z mojego SM-G950F przy użyciu Tapatalka Link to comment Share on other sites More sharing options...
