AEM EMS v2 for 2JZ-GE
Style
AEM EMS v2 ECU for a non-vvti 2JZ-GE engine. I've also got a 3bar map sensor that I'll include as well as the ECU comms cable (firewire to USB conenction) and pinout booklet. Map sensor has been fitted to the car and run for about 100 miles so it's as good as new. Don't have the box for this but it will be suitably packaged for delivery.
Perfect for NA or NA-T guys looking for a full standalone ECU. Comes with heaps of features which I'll list below. This has served me very well and only reason for sale is that I've changed to GTE pickup sensors and need a GTE ECU for that.
Looking for £1100 delivered. Retail new is £1700
http://www.garagewhifbitz.co.uk/aem-ems2-supra-nonturbo.html
SPECIFICATIONS
AEM Series 2 Plug & Play Engine Management System for the 2JZ-GE Non Turbo Supra. AEM's Series 2 EMS is a complete engine control system that plugs into the factory harness and uses the factory sensors. This means you do not need to replace any parts of the harness or sensors, just plug the EMS into the harness and begin tuning! The Series 2 EMS for the 2JZ-GTE allows you to control every aspect of your 2JZ. From VVTi to rev limit, timing, bigger injectors, boost control, nitrous injection, individual cylinder fuel and timing trims and for you drag racers there's even anti-lag! Get total control for your 2JZ-GTE with the Series 2 from our new tuning software - AEM Tuner.
Outputs
Injector Outputs - 12 Peak & Hold
Coil Outputs - 6
Selectable direct drive or 0-5V Coil Output - Yes
Direct plug in, no jumper harness required - Yes
General purpose LS outputs - 11
General purpose HS outputs - 2
Individual cylinder ignition trims - Yes
Individual cylinder fuel trims - Yes
High/Low speed fuel pump support - Yes
Inputs
Trigger inputs (Ref/Sync) - 4
Analog voltage inputs - 14
Configurable Analog/RTD/Thermister inputs - 4
Switch inputs - 5
Lambda inputs - 2x
Knock sensors - 2
User adjustable knock sensor center frequency - Yes
Communication
USB comms - Yes
RS232 comms - Yes
Communication cables included - Yes
Fully enabled editing/logging software included - Yes
CAN bus equipped - Yes
RS232 datastream output - 19 ch
CAN datastream output - 32 ch
Communicates with AIM Dash/Dataloggers - Yes
Communicates with Racepak Dash/Dataloggers - Yes
DATA Acquisition
Internal data logging - 1 MB
Maximum internal logging rate (per channel) - 250 Hz
PC logging - Yes
Data analysis using AEMLog - Yes
Functions and Features
All channels/maps/tuning options unlocked - Yes
Boost control - Yes
Groundspeed based boost target - Yes
Nitrous injection - Yes
Staged injection - Yes
Ground speed limiting - Yes
Rate of Acceleration Control - Yes
Overrun boost enhancement (anti-lag) - Yes
Gear change ignition cut (shift-without-lift) - Yes
Stepper motor idle control - Yes
Password protected calibrations - Yes
Fuel & Ignition rev limiters - Yes
"In cockpit" global fuel trim capability - Yes
Gear dependent shift light - Yes
Evap/Purge function - Yes
DC Motor control - 2 Ch
Software definable "virtual" switch inputs - 2
EGT Based fuel trims - Yes
Maximum boost limit - None
Basic automatic transmission control - No
Advanced automatic transmission control - No
Physical Dimensions
Length - 203 mm
Width - 178 mm
Height - 41 mm
Finish - Black Anodized
Edited by Style
Pics Added (see edit history)
