stevie_b Posted October 12, 2019 Share Posted October 12, 2019 (edited) My NA Supra has failed on "bush excessively worn nearside rear inner (upper rear)". The MOT centre unsurprisingly couldn't source a replacement part. Does anyone know what part I'd need please? Appreciate there's not much info to go on. Would it be this part (see attached) number 48790-19025 ? Or can the bushes be changed without buying a whole new arm? Edited October 12, 2019 by stevie_b (see edit history) Link to comment Share on other sites More sharing options...
Dnk Posted October 12, 2019 Share Posted October 12, 2019 (edited) Heres a diagram of the rear, ive arrowed to the rear upper arm bushes and a photo of the whole lot Edited October 12, 2019 by Dnk (see edit history) Link to comment Share on other sites More sharing options...
stevie_b Posted October 12, 2019 Author Share Posted October 12, 2019 Thanks Dnk: can the bushes be changed without changing the whole suspension arm? It looks like part numbers 90201-14031 and 90201-14020 Link to comment Share on other sites More sharing options...
Dnk Posted October 12, 2019 Share Posted October 12, 2019 You can replace just the two bushes or the complete arm, really depends on the condition of the ball joint if you only change the bushes Not sure if you can buy Toyota bushes, possibly only polybush Link to comment Share on other sites More sharing options...
stevie_b Posted October 12, 2019 Author Share Posted October 12, 2019 That's great, thank you. Link to comment Share on other sites More sharing options...
stevie_b Posted October 12, 2019 Author Share Posted October 12, 2019 It looks like the bushes aren't available separately, so I may get aftermarket bushes to get the MOT renewed. Is it the rear upper wishbone bush I need? https://www.strongflex.eu/en/sc300-sc400/1281-rear-upper-wishbone-bush-5902553511871.html Looking at the list of bushes available, it's a bit of a minefield: https://www.strongflex.eu/en/1097-supra-iv-93-02?orderby=reference&orderway=asc&orderway=asc Link to comment Share on other sites More sharing options...
Dnk Posted October 12, 2019 Share Posted October 12, 2019 its the rear upper wishbone bushes Link to comment Share on other sites More sharing options...
Dnk Posted October 12, 2019 Share Posted October 12, 2019 They appear to have two types with different hardness Link to comment Share on other sites More sharing options...
evinX Posted October 12, 2019 Share Posted October 12, 2019 https://www.ebay.com/itm/FACTORY-SPEC-REAR-UPPER-CONTROL-ARM-SET-QTY-2-FOR-LEXUS-GS300-SC-TOYOTA-SUPRA/232773785906?_trkparms=aid%3D1110001%26algo%3DSPLICE.SIM%26ao%3D2%26asc%3D20160323102634%26meid%3De1e18678ce8e4ea4a9e60c229f775ad1%26pid%3D100623%26rk%3D4%26rkt%3D6%26mehot%3Dpp%26sd%3D371521667125%26itm%3D232773785906%26pmt%3D0%26noa%3D1%26pg%3D2047675&_trksid=p2047675.c100623.m-1 Link to comment Share on other sites More sharing options...
Dnk Posted October 12, 2019 Share Posted October 12, 2019 https://www.ebay.com/itm/FACTORY-SPEC-REAR-UPPER-CONTROL-ARM-SET-QTY-2-FOR-LEXUS-GS300-SC-TOYOTA-SUPRA/232773785906?_trkparms=aid%3D1110001%26algo%3DSPLICE.SIM%26ao%3D2%26asc%3D20160323102634%26meid%3De1e18678ce8e4ea4a9e60c229f775ad1%26pid%3D100623%26rk%3D4%26rkt%3D6%26mehot%3Dpp%26sd%3D371521667125%26itm%3D232773785906%26pmt%3D0%26noa%3D1%26pg%3D2047675&_trksid=p2047675.c100623.m-1 They're a bargin if they are any good, they will cost you £600 + here for both now Link to comment Share on other sites More sharing options...
stevie_b Posted October 12, 2019 Author Share Posted October 12, 2019 Hi Evinx, have you used these yourself? Link to comment Share on other sites More sharing options...
evinX Posted October 12, 2019 Share Posted October 12, 2019 Not yet. Ill need a pair when i clean up my subframe though and will get these. On my wish list. The supra shares the same rear upper arms as the GS300, Aristo and Soarer. So these will fit. Give em a bash mate. Cant complain at that price even after import fees Link to comment Share on other sites More sharing options...
Dnk Posted October 12, 2019 Share Posted October 12, 2019 Not yet. Ill need a pair when i clean up my subframe though and will get these. On my wish list. The supra shares the same rear upper arms as the GS300, Aristo and Soarer. So these will fit. Give em a bash mate. Cant complain at that price even after import fees My concern is there not OEM so how good is the quality Link to comment Share on other sites More sharing options...
evinX Posted October 12, 2019 Share Posted October 12, 2019 Id expect the balljoint and bushes to be fine. Id imagine not being oem the metal may delaminate/ get corrosion like alot of non oem suspension parts quicker. But a nice quick degrease and coat of lacquer would sort that. Id give em a go. Link to comment Share on other sites More sharing options...
Dnk Posted October 13, 2019 Share Posted October 13, 2019 Id expect the balljoint and bushes to be fine. Id imagine not being oem the metal may delaminate/ get corrosion like alot of non oem suspension parts quicker. But a nice quick degrease and coat of lacquer would sort that. Id give em a go. Cheaply made in China would concern me with a such a critical part like this Link to comment Share on other sites More sharing options...
Jellybean Posted October 14, 2019 Share Posted October 14, 2019 The stock top rear arms have spherical bearings in them, not rubber bushes, the rubber boot is there to keep water out. No idea if it is possible the renew the spherical bearing in them or a new arm assembly is required Link to comment Share on other sites More sharing options...
Jellybean Posted October 14, 2019 Share Posted October 14, 2019 On spurious Suspension arms , the rear arms I removed from my Supra and replaced with OE , appeared to be spurious; some swarf on the castings and the upper bush retainer than houses the spherical bearing was cracked I would recommend getting OE Link to comment Share on other sites More sharing options...
