mplavery Posted October 6, 2019 Share Posted October 6, 2019 (edited) Hey peeps So I’ve done a few jobs on the Supra over past few months Done Spark plugs and coil connectors.. tested and ran fan after Then done a oil and filter change Ran fine after Got it up on axle stands/ wheels off to clean inside out and out and to ACF-50 underneath.. Wheels back on and to the ground, started her up and let it warm up About 5 min in it started running really lumpy Notice a hissing noise, spotted a vacuum pipe split by the inlet manifold . Must of disturbed it when removing the filter Worked for a few minutes but lumpy again Replaced few more vacuum pipes but can’t seem to sort it.. might get it spot on for a minute or so then goes lumpy again No doubt it’s a vacuum hose but struggling to see which one it is Anyone else had this issue I will have another look , might be the one under the manifold possibly. Edited October 8, 2019 by mplavery (see edit history) Quote Link to comment Share on other sites More sharing options...
mplavery Posted October 8, 2019 Author Share Posted October 8, 2019 Just to update you guys it’s all sorted Lee (SRD) said to try and disconnect the battery which I did over night. Was 95% better Then I cleaned the idle control valve following Geo how to guide here http://www.mkivsupra.net/vbb/showthread.php?210956-How-To-Clean-Idle-Control-Valve-Cleaning-Aka-ICV-(IAC)&highlight=Idle+control+valve Went for a spin, put new fuel on the tank as I only done about 100 miles this year and boom Sorted Quote Link to comment Share on other sites More sharing options...
