MrGRT Posted September 18, 2019 Share Posted September 18, 2019 Just want to confirm that the circled cables in the photo are the correct ones. Cut pink and join to blue/red cable. Thanks Quote Link to comment Share on other sites More sharing options...
MKIV_Danny Posted September 19, 2019 Share Posted September 19, 2019 Yes thats correct. Cut off the pink cable and connect it to the blue/red cable. Did the same Quote Link to comment Share on other sites More sharing options...
Westy Posted September 19, 2019 Share Posted September 19, 2019 What is this for!? Quote Link to comment Share on other sites More sharing options...
Shane Posted September 19, 2019 Share Posted September 19, 2019 What is this for!? Simply bypasses the buffer circuit in the odo, some think that code 42 and occasional shift problems is caused by this circuit malfunctioning/dry joints, it could be. Pulses from the speed sensor go to the speedo and then through the odo and from there return to the main and PS ECUs and are used for gear changes and presumably other stuff. Quote Link to comment Share on other sites More sharing options...
