safcdixon Posted September 15, 2019 Share Posted September 15, 2019 Hey guys, So I need a littke help, Im going to be putting a oem clutch in my tt6 in the next week or two I currently have a os giken triple plate with the push/pull conversion kit, What Im after is a list of whats needed to replace this giken stuff to take it back to oem, I dont wanna get it dropped out and discover im missing one washer etc, TIA Thanks, Marc Quote Link to comment Share on other sites More sharing options...
Andy Ven Posted September 15, 2019 Share Posted September 15, 2019 Hi marc, I take it you have all the replacement parts already? I guess your just after a list of bolts n stuff? Quote Link to comment Share on other sites More sharing options...
safcdixon Posted September 16, 2019 Author Share Posted September 16, 2019 Hi marc, I take it you have all the replacement parts already? I guess your just after a list of bolts n stuff? /QUOTE] Hey Andy, na ive only got the flywheel at the min, ive basically no idea what i need to replace the giken kit, when it comes to the manual side of supras ive no idea Quote Link to comment Share on other sites More sharing options...
Andy Ven Posted September 16, 2019 Share Posted September 16, 2019 Hi marc, Ive got a full setup for sale as ive just changed my stock setup for an os giken r3c kit. May i ask why your changing from the giken clutch? Quote Link to comment Share on other sites More sharing options...
safcdixon Posted September 17, 2019 Author Share Posted September 17, 2019 Hi marc, Ive got a full setup for sale as ive just changed my stock setup for an os giken r3c kit. May i ask why your changing from the giken clutch? /QUOTE] Yeah the im having issues with it failing out of adjustment mate, works fine one day, park it up for a week or so get back in to use it and the adjustment is out, happend twice now so ive basically just ran out of patience with it, also my rear crank seal is weaping so if the box is coming off im going to remedy the problem at this point, clutch is great when its working btw great feel, great grab etc Quote Link to comment Share on other sites More sharing options...
Andy Ven Posted September 17, 2019 Share Posted September 17, 2019 Yeah the im having issues with it failing out of adjustment mate, works fine one day, park it up for a week or so get back in to use it and the adjustment is out, happend twice now so ive basically just ran out of patience with it, also my rear crank seal is weaping so if the box is coming off im going to remedy the problem at this point, clutch is great when its working btw great feel, great grab etc Hey mate, by adjustment is out, do you mean when you press the brake pedal that it doesn’t disengage? If thats your issue then sounds to me like your clutch master cylinder is faulty. Ive got all the parts to go to stock if you are interested. Just shoot me a Pm and im sure we can work somthing out. Cheers Andy Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted September 18, 2019 Share Posted September 18, 2019 Hey mate, by adjustment is out, do you mean when you press the brake pedal that it doesn’t disengage? If thats your issue then sounds to me like your clutch master cylinder is faulty. Ive got all the parts to go to stock if you are interested. Just shoot me a Pm and im sure we can work somthing out. Cheers Andy /QUOTE]I'm pretty sure that if the clutch was to disengage when pressing the brake pedal, he has bigger problems to worry about [emoji23] Sent from my SM-N960F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Andy Ven Posted September 19, 2019 Share Posted September 19, 2019 I'm pretty sure that if the clutch was to disengage when pressing the brake pedal, he has bigger problems to worry about [emoji23] /QUOTE] My bad [emoji23] clutch pedal... you know what i mean [emoji23] Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted September 19, 2019 Share Posted September 19, 2019 My bad [emoji23] clutch pedal... you know what i mean [emoji23] /QUOTE][emoji23][emoji23] Sent from my SM-N960F using Tapatalk Quote Link to comment Share on other sites More sharing options...
