Glover Posted September 13, 2019 Share Posted September 13, 2019 I ordered a new water pump the other week, not the full housing just the front actual pump section. The one I was sent was not the right one for my car even though it should have been! Has anyone got the correct part number or can point me in the right direction. 93 JDM Manual 2JZ-GE. Reg is K930PFB. Do the different GE engines have different water pumps ?? Link to comment Share on other sites More sharing options...
Style Posted September 13, 2019 Share Posted September 13, 2019 I believe the pumps themselves are the same but the housings are different. Part number should be 16100-49097 Link to comment Share on other sites More sharing options...
Glover Posted September 13, 2019 Author Share Posted September 13, 2019 Perfect, thank you!!! I wondered if they changed over the years or maybe the Lexus 2JZ’s might be slightly different as this one doesn’t line up with the holes on the pump with the housing. Link to comment Share on other sites More sharing options...
evinX Posted September 13, 2019 Share Posted September 13, 2019 I got 2 halves sat here. From Blueprint, the gasket failed but the casings are clean to be fair and the gear/pump is clean to. If any use you can have the front half for 25 delivered. Just need a METAL gasket. Blueprint/ GMB used some gluey gasket Link to comment Share on other sites More sharing options...
Swampy442 Posted September 13, 2019 Share Posted September 13, 2019 Lexus 2J, Toyota 2J all the same engines. The pump section is common across all 1 and 2J engines, as stated above the rear housings are different Link to comment Share on other sites More sharing options...
Glover Posted September 13, 2019 Author Share Posted September 13, 2019 Thanks for the info. I’ve sourced the full housing now an Aisin one same as what I’ve taken off. Link to comment Share on other sites More sharing options...
