Supra Window switches
Fulcrum2000
Hey
I'm trying to find some part numbers and need the number for that bit of trim that goes around the electric window switches on the drivers door, on the plans it just says refer to diagram 74 01 and thats just the sun visors? Mine is perhaps the most worn part of my interior for some reason and I want to get a new one. My AC was completely broken when I bought it which perhaps explains the over use of windows! All fixed now though :) Anyone know the number for this bit?
  • 2 weeks later...
If it's the original rubberised finish, you can strip it using acetone and a rag - it's laborious and messy, but it works.
Then you can use black plastidip to repaint it, wilhich is an almost perfect oem pfl match. If your panel is facelift, you're out of luck, as there isn't really a product that matches very well.
