Cam27 Posted September 4, 2019 Share Posted September 4, 2019 (edited) I have a load of parts that I no longer need after going single, hopefully can be of use to someone. Blitz BOV & joiner for stock location £40 *sold* TT6 flywheel £80 Oem power steering lines and cooler £50 *sold* GTE 100 amp alternator £50 GTE stock fuel rail, injectors and regulator £40 O2 (lambda) sensors x2 £15 each HKS fuel cut defender (with original packaging, instructons etc) £40 *sold* HKS EVC-S boost controller £90 TT6 pre vvti J spec ECU £250 Vacuum pressure tank £20 Oem MAP sensor £20 W58 shifter tripod £35 Sard radiator cap £10 Exhaust restrictor ring £8 Carbon coil pack cover, cut to fit with clear cam cover £50 New oem vacuum hose no.8 x2 (small 90 degree vacuum hoses down the back of vacuum hard lines) £10 each Silicone GTE top radiator hose £10 *sold* Oem fuel tank cover £80 *sold* Water temp sensor £10 AC condensor £40 *sold* Brake booster £30 New oem cam cover gaskets (pair) £15 *sold* New oem rear crank seal £30 *sold* New oem timing cover gasket set x2 £15 each *1 set sold* New oem full set of valve stem seals £50 *sold* New oem camshaft seals (pair) £15 *sold* New oem GTE head gasket £100 *sold* New oem full set of injector seals £30 I also have the hybrid turbos, pipework, vsvs etc but will make a seperate post for that. I will try add any pictures that are missing later today. Cheers, Cam Edited September 13, 2019 by Cam27 (see edit history) Link to comment Share on other sites More sharing options...
curious Posted September 4, 2019 Share Posted September 4, 2019 Pm sent. Thanks Link to comment Share on other sites More sharing options...
shervin_ice Posted September 4, 2019 Share Posted September 4, 2019 Cam seals are for gte or Vvti ? Link to comment Share on other sites More sharing options...
Cam27 Posted September 4, 2019 Author Share Posted September 4, 2019 Cam seals are for gte or Vvti ? /QUOTE] Gte non vvti mate Link to comment Share on other sites More sharing options...
bonus_2000 Posted September 4, 2019 Share Posted September 4, 2019 Pm re cam cover gaskets and top rad pipe. Link to comment Share on other sites More sharing options...
drift_bear Posted September 5, 2019 Share Posted September 5, 2019 I’ll take the VSS dude Link to comment Share on other sites More sharing options...
Swampy442 Posted September 5, 2019 Share Posted September 5, 2019 Is the price for the alternator including shipping? Link to comment Share on other sites More sharing options...
Cam27 Posted September 5, 2019 Author Share Posted September 5, 2019 Is the price for the alternator including shipping? No mate, be a tenner for shipping Link to comment Share on other sites More sharing options...
Brian_C1 Posted September 5, 2019 Share Posted September 5, 2019 PM'd Link to comment Share on other sites More sharing options...
MrRalphMan Posted September 6, 2019 Share Posted September 6, 2019 Hiya, if the AC condenser is in good condition, I.e.no leaks, I'd like to grab it. How much would shopping be, unless you're anywhere near Essex. Paul Link to comment Share on other sites More sharing options...
Brian_C1 Posted September 13, 2019 Share Posted September 13, 2019 Are the parts I PM'd about still available as I didn't get a reply, thanks Link to comment Share on other sites More sharing options...
Cam27 Posted September 13, 2019 Author Share Posted September 13, 2019 Are the parts I PM'd about still available as I didn't get a reply, thanks Hi mate, I don't have a pm from you in my inbox!? Let me know what you are after Link to comment Share on other sites More sharing options...
Brian_C1 Posted September 13, 2019 Share Posted September 13, 2019 Hi mate, I don't have a pm from you in my inbox!? Let me know what you are after Looking for lot price on the cam seals, cam cover gaskets and valve stem seals posted to Ireland but UK will be fine also if Ireland is too dear. Cheers Link to comment Share on other sites More sharing options...
MrGRT Posted September 13, 2019 Share Posted September 13, 2019 What do you still have left? Link to comment Share on other sites More sharing options...
Izzy Posted September 13, 2019 Share Posted September 13, 2019 pm sent Link to comment Share on other sites More sharing options...
Cam27 Posted September 13, 2019 Author Share Posted September 13, 2019 For sale list now updated - - - Updated - - - Looking for lot price on the cam seals, cam cover gaskets and valve stem seals posted to Ireland but UK will be fine also if Ireland is too dear. Cheers All sold buddy sorry Link to comment Share on other sites More sharing options...
