Identifying this engine loom
ReisenBagels
Morning everyone,
Received this engine loom to fit on my 2jz-ge from a friend with a 2jz-ge m/t ECU. At the time did not get time to check the connectors to see if it plugs straight in only to realise the plugs are smaller.
Just wondering if it is the correct loom but I am missing something else such as a junction box that converts it to plugs to the ECU.
Any help is appreciated
-Isaac
After hours of searching I've found that this is the 2jz-gte vvti harness, Do you guys happen to know if this will still be a fit for the non-vvti or should I poke keron for a non-vvti engine harness.
https://www.jdm-import.com/jdm-shop/interior/gauges-boost-controllers/toyota-2jz-gte-vvti-engine-harness/#
https://www.jdm-import.com/wp-content/uploads/2017/12/HNS102_3.jpg
Cheers
Can you take some better photos? We also need to establish if you have a 2JZVVTI GTE loom from an Aristo, or a Supra. It's not really a lot of help if its from an Aristo, and a Supra VVTI loom won't work on a 2JZGE, but it will be worth lots of money, so you could sell and buy the loom you need
