What at fault here out the two?? Injector help also.
Imperialrs
Hi there got toyota Aristo 2jz gte engine, non vvti and it had the waterpump with built in system from hydrofan. Now i have removed the pump and replaced with a water pump from a toyota supra. The water pump fits perfectly however the new alternator i have is fouling the water pump so the top hole doesnt line up. The water pump was complete with back housing.
Is the alternator or you think the Waterpump thats the problem.
Pictures attached.
looking for 800cc side fed injectors, any recommendations of where to get a set and what brand is best. I know you can get top feed rail but trying to avoid that if possible.
Right got some pictures today. Just cant seem to think why the alternator would foul the water pump.
The pulley lines up with rest of the pulleys.
To confirm its an aristo 2jz gte 1995 non vvti, i purchased a supra water pump kit and fitting it as i didnt want all the crap to do with the hydrofan. The water pump complete with back housing and was bolted on. The aristo alternator was then replaced with a supra alternator. Is the alternator slightly different?
