Imperialrs Posted August 23, 2019 Share Posted August 23, 2019 There are three seals not where they go? Anyone help, other ones i figured out but dont remember seeing the other 3 come off the engine when i took pump off? Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted August 23, 2019 Share Posted August 23, 2019 1 seal is for the back of the pump to the block. Two small rings are for the water bypass tube that connects to water pump from upper water neck. Other big ring is thermostat o ring Quote Link to comment Share on other sites More sharing options...
Imperialrs Posted August 23, 2019 Author Share Posted August 23, 2019 Hi thanks for reply the two small ones and gasket I’ve Blanked out a i know what they are So one seal is for pump to block One for thermostat That leaves one other big seal? Quote Link to comment Share on other sites More sharing options...
