mos Posted May 5, 2003 Share Posted May 5, 2003 Has anybody removed their viscous fan and fitted an electrical one instead, The reason i ask is my viscous shroud is damaged and caused my car to overheat at the m5/m6 interchange. It might be cheaper to fit an electrical unit instead of buying a shroud and its less things for the belt to drive then as well. If anybody has what size did you use and any overheating problems Link to comment Share on other sites More sharing options...
banaman69 Posted May 5, 2003 Share Posted May 5, 2003 im also interested to replace the vicsoe fan with an electric fan,probably be a Kenlowe. Link to comment Share on other sites More sharing options...
Wez Posted May 5, 2003 Share Posted May 5, 2003 There is a thread here with some info in it :- http://www.mkivsupra.net/vbb/showthread.php?threadid=5503&highlight=electric+fan Here are the search results :- http://www.mkivsupra.net/vbb/search.php?action=showresults&searchid=47337&sortby=lastpost&sortorder=descending Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 5, 2003 Share Posted May 5, 2003 It'll be cheaper to fix the stock shroud, the engine driven fan is LARGE, moves a LOT of air, and is properly ducted, an equivalent electric one will be expensive, maybe even inadequate in certain conditions. Keeping the shroud for the A/C supplement fan AND fitting a shrouded adequately sized electric one could be tricky. You'd be surprised how much air the stock one moves withe the viscous engaged on a hot engine at 4000 RPM, far more than an electric could manage without about a 3HP motor, which would be enormous. Link to comment Share on other sites More sharing options...
mos Posted May 5, 2003 Author Share Posted May 5, 2003 SORRY didnt do a search big mistake and i hold my hands up to it. Well its all a bit confusing some people have had no snags and yet some people have had a few. I was thinking of fitting the fans direct to the radiator as i dont have a seperate A/C fan. However what chris has said makes good sense, if the car overheated with a bit missing from the shroud then it must move a super amount of air. Link to comment Share on other sites More sharing options...
Dragonball Posted May 5, 2003 Share Posted May 5, 2003 Have a word with John (dudsvr) who has two electrics on his Not sure of the spec etc They do look the dog's and makes getting to everything sooo much easier! Cheers Paul Link to comment Share on other sites More sharing options...
Guest Usmann A Posted May 5, 2003 Share Posted May 5, 2003 "THEY LOOK THE DOGS" paul E That'll be a Kirsty then.......... Sorry.... Link to comment Share on other sites More sharing options...
GavinL Posted May 5, 2003 Share Posted May 5, 2003 Originally posted by Paul E Have a word with John (dudsvr) who has two electrics on his Not sure of the spec etc They do look the dog's and makes getting to everything sooo much easier! Cheers Paul Check also that the car has seen a hot summers day in heavy traffic or a trackday Link to comment Share on other sites More sharing options...
Steve W Posted May 5, 2003 Share Posted May 5, 2003 Martin F's got 2 on his..... YES, makes getting to T-Belt etc MUCH easier... but, as Chris says Martin's TWO probably still don't move as much as ONE viscous (it IS big.... ooh err) Suprisingly, I find with the original viscous, the Soop STILL warms-up VERY quickly, even on Winter mornings... AND THAT is the MAIN reason for going electric....to make warm-ups quicker (and use less power when no cooling is needed) Link to comment Share on other sites More sharing options...
