AEM AFR problem
kslb
Good evening, the gauge for my AEM AFR stays on 14.8 I am assuming I just need to remove the sensor and give it a clean but thought I would check on here first. It runs round the dial on start up as expected and fluctuates a little then sticks on 14.8. The car runs fine and the wiring seems good but before I get the lemon juice out I thought it was worth checking if anyone else had a similar issue. Car has been in storage for a while as well.
Many thanks.
