Help needed,
Imperialrs
Help needed: The two sensors, what are they? I have a feeling the blue one is water temperature, not sure what black one is?
Couple of other questions:
1. The fuel into the inlet manifold is at the end closest to bulkhead and return near the middle behind injectors.
2. Looking for size of the bolt that blanks off the right hand oil feed to turbo when doing single turbo conversion.
3. How huge a difference does it make having internal wastegate compared to external?
Thanks in advance. Picture should be attached.
