slugger1 Posted August 14, 2019 Share Posted August 14, 2019 As title suggests I need to find a replacement for mine that has separated. I believe the part number is 13407-46020. Cheers, Stuart Link to comment Share on other sites More sharing options...
Style Posted August 14, 2019 Share Posted August 14, 2019 Paul at TCB Parts is your man. I bought a new one about a month ago and he was easily the cheapest. £160+VAT http://www.tcbparts.co.uk/ Link to comment Share on other sites More sharing options...
slugger1 Posted August 14, 2019 Author Share Posted August 14, 2019 Paul at TCB Parts is your man. I bought a new one about a month ago and he was easily the cheapest. £160+VAT http://www.tcbparts.co.uk/ Cheers, I will give him a try. I have seen replacement parts on eBay for £46.50 but not sure if I trust them though! Link to comment Share on other sites More sharing options...
Style Posted August 14, 2019 Share Posted August 14, 2019 Yeah there's a thread on here somewhere about the non genuine ones http://www.mkivsupra.net/vbb/showthread.php?354049-Cheapo-crank-pulley-Or-not Link to comment Share on other sites More sharing options...
slugger1 Posted August 14, 2019 Author Share Posted August 14, 2019 Yeah there's a thread on here somewhere about the non genuine ones http://www.mkivsupra.net/vbb/showthread.php?354049-Cheapo-crank-pulley-Or-not Cheers. I have ordered one from TCB along with a replacement crank bolt. Better to be safe than sorry! Link to comment Share on other sites More sharing options...
Swampy442 Posted August 14, 2019 Share Posted August 14, 2019 Nice one, dont cheap out on such an important part Link to comment Share on other sites More sharing options...
slugger1 Posted August 15, 2019 Author Share Posted August 15, 2019 Nice one, dont cheap out on such an important part Hopefully once replaced it might sort out my misfire problem! I understand the crank position sensor might have been affected if the crank pulley has been failing for some time? Link to comment Share on other sites More sharing options...
Scooter Posted August 15, 2019 Share Posted August 15, 2019 Not heard about that before? Misfires are normally all related to the coil packs and clips/loom to the plugs......but I think you've been through some of those? Link to comment Share on other sites More sharing options...
slugger1 Posted August 15, 2019 Author Share Posted August 15, 2019 Not heard about that before? Misfires are normally all related to the coil packs and clips/loom to the plugs......but I think you've been through some of those? Yes I've been through all of those! A mate at work had a similar issue with a car they used for racing and suggested that my issue could be related to the crank sensor if the pulley was out of position and it was sending incorrect information back to the ECU. I'm hoping that it is the cause of my misfire as I can get 2 problems solved in one! Link to comment Share on other sites More sharing options...
Brian_C1 Posted August 15, 2019 Share Posted August 15, 2019 Yes I've been through all of those! A mate at work had a similar issue with a car they used for racing and suggested that my issue could be related to the crank sensor if the pulley was out of position and it was sending incorrect information back to the ECU. I'm hoping that it is the cause of my misfire as I can get 2 problems solved in one! Stupid question but did you replace the plugs aswel as the coil packs and clips? I had a section of cracked porcelain on one of my plugs which was causing a misfire Link to comment Share on other sites More sharing options...
Scooter Posted August 15, 2019 Share Posted August 15, 2019 Yes I've been through all of those! A mate at work had a similar issue with a car they used for racing and suggested that my issue could be related to the crank sensor if the pulley was out of position and it was sending incorrect information back to the ECU. I'm hoping that it is the cause of my misfire as I can get 2 problems solved in one! The crank sensor itself could give issues, not sure of their failure mode. The timing star can give issues but I think that seems to stop running if it comes loose not give intermittent/misfire symptoms. How bad is the misfire, when does it do it more/less? Link to comment Share on other sites More sharing options...
slugger1 Posted August 15, 2019 Author Share Posted August 15, 2019 The plugs and coil packs have been changed. - - - Updated - - - The crank sensor itself could give issues, not sure of their failure mode. The timing star can give issues but I think that seems to stop running if it comes loose not give intermittent/misfire symptoms. How bad is the misfire, when does it do it more/less? At idle you can here that it is missing. Under load the car struggles to put the power down and labours. Link to comment Share on other sites More sharing options...
Swampy442 Posted August 15, 2019 Share Posted August 15, 2019 Could be an ECU failing? Also just double check the timing just to be sure. In my experience with a crank sensor it either works or it doesn't, and when it doesn't work neither does the engine lol Link to comment Share on other sites More sharing options...
slugger1 Posted August 16, 2019 Author Share Posted August 16, 2019 Could be an ECU failing? Also just double check the timing just to be sure. In my experience with a crank sensor it either works or it doesn't, and when it doesn't work neither does the engine lol I'm having the timing belt changed at the same time as the crank pulley replacement so I will see how it is after that. I expect it will still be running like crap again! Link to comment Share on other sites More sharing options...
