Pas pump repair
coza
Not such a daunting task, that's good to know thanks for update. What was it that prompted you to refurb.
I occasionally get a whirring or juddering when turning wheels, usually a low speed maneuvers. This is what I'm guessing is to do with pump,
  • 3 weeks later...
I keep most of the bits to rebuild them, but don't want to sell the bits separately, but I will rebuild your old pump if it's not scored to buggery. I can also source new ones that actually work unlike most of the none OE ones on Ebay. Is the reservoir OK, many are now choked up and they are complex inside often thorough cleaning fails to get them correct and a new one is the only fix. Tight track usage demands a better cooler...
