Cyl.hd.gasket. New. Mk4. Na. 2jz-ge. Engine.
herbiemercman
Hi Guys, I have a new cylinder head gasket for the 1994 to 1997, 2JZ-GE. engine. NA or NAT. It is the OEM spec with improved steel laminate construction for better longevity. The compression ration is also maintained. £35. and P&P £3.25. Herbie.
Edited by herbiemercman
altered text due to ebay clashing, now canc. (see edit history)
Hi Guys, I will put this item on ebay now, i just thought i would see if a member wanted one first. I also realize that you only purchase an item like this when you have a problem and i hope you do not as changing the head gasket is a long winded technical difficult job. Herbie.
