mrboomberang Posted July 31, 2019 Share Posted July 31, 2019 Was thinking about fitting cruise control to my 1997 tt vvti auto tiptronic has anyone done this mod Link to comment Share on other sites More sharing options...
David P Posted July 31, 2019 Share Posted July 31, 2019 I retrofitted cruise control to my non VVTi auto. This is not a job for the feint hearted, further to the control motor, cable and control stalk, it also requires a 4-pin brake light switch and an extensive number of additional wires. For these I found it easier to remove the dash and change the bulkhead loom for one that already had the cruise wiring. Link to comment Share on other sites More sharing options...
j_jza80 Posted July 31, 2019 Share Posted July 31, 2019 (edited) Was thinking about fitting cruise control to my 1997 tt vvti auto tiptronic has anyone done this mod /QUOTE] Realistically, you wont be able to do to this without spendinng a lot of money. The vvti uses a crap semi-dbw throttle setup from the factory, featuring the worst aspects of both cable driven and dbw throttle setups. As npne of the vvti tiptronics came with cruise, you have no factory parts to use for the swap. I have it on mine, but only because of my 911 yurbo dbw throttle body and syvecs ecu, and even then it doesnt work well. You may be able to use aristo vvti patts as i believe some of them have cruise, but the ecu isnt interchangeable with the supra. Edited July 31, 2019 by j_jza80 (see edit history) Link to comment Share on other sites More sharing options...
blythmrk Posted July 31, 2019 Share Posted July 31, 2019 I have the control motor if any good drop me a pm I would have to check if I have anything else to go with it! Link to comment Share on other sites More sharing options...
David P Posted August 3, 2019 Share Posted August 3, 2019 Maybe a universal aftermarket unit would do the trick? http://www.rostra.com/universal-aftermarket-cruise-control-by-rostra.php Link to comment Share on other sites More sharing options...
wile e coyote Posted August 3, 2019 Share Posted August 3, 2019 Maybe a universal aftermarket unit would do the trick? http://www.rostra.com/universal-aftermarket-cruise-control-by-rostra.php i looked into this exact model but shelfed it Link to comment Share on other sites More sharing options...
