R154 diff recommendations
shervin_ice
What about A02A open diff but from tt auto ?
Thanks for your input [emoji106]
/QUOTE]
It will have a longer drive for each gear. You'll have a higher speed for each gear.
It will drag out each gear. LSD or Open doesn't make a difference to the ratio.
Stick with a diff intended for an NA. Jekyl put a TT auto diff in his NAt years ago. He said it drove like the car was down on power if I remember correctly.
If you already have an A02A in the car, and you want to put a A02B in the car then it will feel exactly the same in terms of ratio. The only difference will be when the back end steps out, it will feel more stable as A02B uses torsion LSD.
Okay but do you know if the NA DIFF can handle 550 to 650BHP or more bhp ?
