Dnk Posted July 20, 2019 Share Posted July 20, 2019 Anyone used it ? I'd like some feedback if you have, on the clear product they do Link to comment Share on other sites More sharing options...
Sheefa Posted July 20, 2019 Share Posted July 20, 2019 Yep. A few times mate on plastic bits (broken clips, door draft excluders etc) always worked a treat. Link to comment Share on other sites More sharing options...
Dnk Posted July 20, 2019 Author Share Posted July 20, 2019 Yep. A few times mate on plastic bits (broken clips, door draft excluders etc) always worked a treat. /QUOTE] Cheers Greg, was this the clear version they do ? is it like super glue and sets rock hard ? I'm looking to bond this painted metal strip to a plastic dash board as its cracking around the vents, i can't see an easier way of fixing it, the cracks have all all been repaired so i'm trying to add some strength to the brittle area Link to comment Share on other sites More sharing options...
Sheefa Posted July 20, 2019 Share Posted July 20, 2019 This one mate I use Link to comment Share on other sites More sharing options...
Sheefa Posted July 20, 2019 Share Posted July 20, 2019 Cheers Greg, was this the clear version they do ? is it like super glue and sets rock hard ? I'm looking to bond this painted metal strip to a plastic dash board as its cracking around the vents, i can't see an easier way of fixing it, the cracks have all all been repaired so i'm trying to add some strength to the brittle area Yes it bonds really hard like ultra tough superglue. It's a bit like epoxy but easier to apply. I have used a few types over the years see enclosed and this works best. Link to comment Share on other sites More sharing options...
Dnk Posted July 20, 2019 Author Share Posted July 20, 2019 Cheers Greg, think i'll give that a try There are some many adhesives out there its mind numbing Link to comment Share on other sites More sharing options...
Sheefa Posted July 20, 2019 Share Posted July 20, 2019 Cheers Greg, think i'll give that a try There are some many adhesives out there its mind numbingI know mate, I have tried a good 5-6 over last few years and the Gorilla is right at the top. Good luck! Link to comment Share on other sites More sharing options...
Style Posted July 21, 2019 Share Posted July 21, 2019 My daily failed it’s MOT on an insecure front headlight. Turns out the bottom bracket had snapped and was a common fault. Gorilla glued it 3 years ago and it’s been fine ever since Link to comment Share on other sites More sharing options...
Dnk Posted July 21, 2019 Author Share Posted July 21, 2019 My daily failed it’s MOT on an insecure front headlight. Turns out the bottom bracket had snapped and was a common fault. Gorilla glued it 3 years ago and it’s been fine ever since Sounds good, which Gorilla glue did you use ? Link to comment Share on other sites More sharing options...
Style Posted July 22, 2019 Share Posted July 22, 2019 Sounds good, which Gorilla glue did you use ? Same one as Greg mate Link to comment Share on other sites More sharing options...
Dnk Posted July 23, 2019 Author Share Posted July 23, 2019 Same one as Greg mate Link to comment Share on other sites More sharing options...
fullthrottle Posted July 24, 2019 Share Posted July 24, 2019 Never used it but I can recommend tiger seal it's used for bonding on body kits/ spoilers to metal panels Link to comment Share on other sites More sharing options...
Dnk Posted July 24, 2019 Author Share Posted July 24, 2019 Never used it but I can recommend tiger seal it's used for bonding on body kits/ spoilers to metal panels I was thinking maybe i should use this as it has a little flex when its set which could be better Link to comment Share on other sites More sharing options...
fullthrottle Posted July 24, 2019 Share Posted July 24, 2019 I was thinking maybe i should use this as it has a little flex when its set which could be better Exactly this as I am sure you know you get body flex and this tiger seal still keeps the bodykit stuck to metal Link to comment Share on other sites More sharing options...
