Supra parts
Supraleeturbo
All prices and not including postage, if you need pictures please send me your number or email
Fmic pipe 20
Full timing cover 50
Fuse box no lid 50
Ac bracket 40
Blitz sus 80
Non vvti rad fan 20
Vvti engine brackets 100
Na top water neck 50
Rear belts 50
Na front decat 80
Cam pully cover 40
Pullys 5 each
Fan gear 20
Over flow tank 20
Exhaust hanger 30
Air ducts 15 each
Abs ecu 20
Fuel sensor/ECU? 10
Auto pedal covers 10
2.5 second decat 80
Stock sill trims 50
Boot trim 20
Door shut sills 10 each
Rad air duct 20
auto dip stick 10
Bonnet stay 10
Rear upper arms nearly new 250 each
Anti roll bars 80
Front sub frames 250 each
Front wheel arch plastic 50 2 sets
Lower timing cover 25
Hks ssqv bov 50
Brake master 50
1 left lights 25 each
Oil strainer 30
Prop shaft 250
Abs hubs with drive shafts ect 250 each side
Edited by Supraleeturbo (see edit history)
Just to confirm we are talking front half lining with air vents, if so what condition are they in? I've rubbing on arches. All being good I'll take a set, left and right. Can you post to London, or near enough for me to collect? Cheers Chas
/QUOTE]
Hi bud we are talking the arch liners buddy no vents
Yeah I thought I would check, I think the parts I'm after are called wheel arch liners front left/right. They all get rub wear and chucked. Thank tho glws
/QUOTE]
I think what you're looking for mate are the 'wheel splash guards'. Part numbers are 53896-14010 and 53895-14010.I recently ordered the passenger side from Amayama
