John GT Posted July 18, 2019 Share Posted July 18, 2019 Hi All, I've a MK4 TT6 with a Apexi power FC ecu running first cat but standard after that. When I accelerate hard from 2500 - 3200 RPM, my engine management light flickers on and off quickly until I hit 3500 or more and it remains off then until I repeat the same steps. Th red triangle illuminates with the eml but turns off when eml turns off. There appears to be no drop in performance when this occurs so I don't think its fuel cut. Seen on another thread about brake fluid being low but topped it up with no change in issue. I'll no FC Commander but not entirely sure what it will show me. Not sure if I can diagnose with short codes as its aftermarket ECU. Would there be anyone else running the Apexi ecu here? Thanks Link to comment Share on other sites More sharing options...
Ric Posted July 18, 2019 Share Posted July 18, 2019 Is the brake fluid realllllly full. They are very sensitive. wouldn't be surprised if it needs a bit more in Link to comment Share on other sites More sharing options...
John GT Posted July 18, 2019 Author Share Posted July 18, 2019 Is the brake fluid realllllly full. They are very sensitive. wouldn't be surprised if it needs a bit more in I'll have another look but fairly certain its just slightly over the max line. Link to comment Share on other sites More sharing options...
John GT Posted July 30, 2019 Author Share Posted July 30, 2019 I had a look at this over the weekend, brake fluid was a small bit over the max line but top it up ever so slightly. I took it for a spin and though everything was fine but after planting it the second time the same EML flicker came on Is the only way to read fault codes through the FC commander? I don't have one currently. Link to comment Share on other sites More sharing options...
RobMason Posted July 31, 2019 Share Posted July 31, 2019 When I had a Power FC on my MR2 I was told that it would flash the EML when knock was detected, if your map isn't 100% it would kind of explain why you see it under hard acceleration. Link to comment Share on other sites More sharing options...
