tayr Posted July 14, 2019 Share Posted July 14, 2019 (edited) Fitted the new antenna today however it doesn’t retract all the way. If I turn the ignition on and allow to come up halfway and turn the ignition off again it goes down all the way, but if I let it get all the way up to the top it doesn’t go all the way down. It stops about 6-8” up Any ideas ?? Also - is this height normal? Never had one working so seems a bit high. I’ve taken the thing apart so many times today I’ve given up for now https://vimeo.com/348051913 Edited July 14, 2019 by tayr (see edit history) Link to comment Share on other sites More sharing options...
Andy Ven Posted July 14, 2019 Share Posted July 14, 2019 Taylor, it looks to me like a mechanical issue. Upon full extension, the very last section is being forced out to its stop. The only thing i can think is the last section is too tight in its sleeve and is locking when it his its stop. I guess you have tried wd40 the sections by the pic of the can in the car. Link to comment Share on other sites More sharing options...
tayr Posted July 14, 2019 Author Share Posted July 14, 2019 Taylor, it looks to me like a mechanical issue. Upon full extension, the very last section is being forced out to its stop. The only thing i can think is the last section is too tight in its sleeve and is locking when it his its stop. I guess you have tried wd40 the sections by the pic of the can in the car. Yeh I did try the wd40 but might give it another go to try and loosen it up, it didn’t feel too tight but I am stronger than a 23 year old Toyota motor Link to comment Share on other sites More sharing options...
Sheefa Posted July 15, 2019 Share Posted July 15, 2019 Must be getting stuck there or at base. You could try WD40 and a bit of heat applied, maybe boiling water to ease any grease. You can also buy new replacement masts not just the motor. Link to comment Share on other sites More sharing options...
