puggy Posted July 9, 2019 Share Posted July 9, 2019 Hi guys, I'm looking for some advice on how to change the outer window seals (the ones that run parallel with the bottom of the driver/passenger windows). Do I need to remove the door card etc or can I replace them just by winding the window down? I see that there are clips on the new ones so does it just un-clip or are there screws or something else involved? I know that to many, this might not seem to technical but to me, it's like changing an engine! Any advice would be much appreciated! Thanks Link to comment Share on other sites More sharing options...
Westy Posted July 9, 2019 Share Posted July 9, 2019 Remove door card....star screwdriver and hammer required. Tap screws to break seal of the lock tight and remove....there is one either end. Reverse the process. Simple job Link to comment Share on other sites More sharing options...
puggy Posted July 9, 2019 Author Share Posted July 9, 2019 Perfect, ta! Link to comment Share on other sites More sharing options...
