tayr Posted July 2, 2019 Share Posted July 2, 2019 Hi guys i've got a rattle when pulling away slowly with the clutch and a little bit of revs, sounds like a metal pole dragging on the floor but there is nothing hanging down. any ideas on what to check? I'm trying to upload a video - car drives fine so not sure what it could be.. Manual TT6 Link to comment Share on other sites More sharing options...
Mike2JZ Posted July 2, 2019 Share Posted July 2, 2019 Sounds like dual mass flywheel, unless you have an uprated clutch Link to comment Share on other sites More sharing options...
tayr Posted July 2, 2019 Author Share Posted July 2, 2019 Sounds like dual mass flywheel, unless you have an uprated clutch ive no idea mate, what’s the best way of checking? Link to comment Share on other sites More sharing options...
Mike2JZ Posted July 2, 2019 Share Posted July 2, 2019 ive no idea mate, what’s the best way of checking? Take inspection plates on gearbox off and peer inside. Can tell from pressure plate if its oem setup. Checking flywheel is more difficult, easiest with gearbox off Link to comment Share on other sites More sharing options...
Scooter Posted July 3, 2019 Share Posted July 3, 2019 If you are rolling along at walking pace and sort of clutch dump (bring it up to the bite point sharply) does it sound like a bag of spanners, but ok with the clutch down and after it's engaged and under steady power? If you roll to close to stalling then give a little throttle does it also do this noise and feel far from smooth? Those are the non technical flywheel symptoms I think....... Link to comment Share on other sites More sharing options...
