Mgrene Posted June 29, 2019 Share Posted June 29, 2019 Hello Forum. The reason for asking is because when I check the dipstick when the engine is hot, the dipstick only shows half full but when checking when the engine is cold, it shows full. I always used to check when the engine is hot but looks like it is not the way forward with my current Supra. Anyone who has ecperienced the same? Link to comment Share on other sites More sharing options...
wile e coyote Posted June 29, 2019 Share Posted June 29, 2019 (edited) Cold obviously the oil will have drained down and will show high on dipstick Hot depends how soon after you turn off If hot and just turned off it will show lower on the stick until oil eventually drains down after 5 minutes or so There are 2 oil warning lights Yellow for low level Red for low oil pressure Edited June 29, 2019 by Tyson (see edit history) Link to comment Share on other sites More sharing options...
Mgrene Posted June 29, 2019 Author Share Posted June 29, 2019 Cold obviously the oil will have drained down and will show high on dipstick Hot depends how soon after you turn off If hot and just turned off it will show lower on the stick until oil eventually drains down after 5 minutes or so There are 2 oil warning lights Yellow for low level Red for low oil pressure - - - Updated - - - Cold obviously the oil will have drained down and will show high on dipstick Hot depends how soon after you turn off If hot and just turned off it will show lower on the stick until oil eventually drains down after 5 minutes or so There are 2 oil warning lights Yellow for low level Red for low oil pressure My warning lights doesn’t work unfortunately. When I check the dipstick while the engine is hot I normally do it approx. 10 minutes after the engine is off. Link to comment Share on other sites More sharing options...
wile e coyote Posted June 29, 2019 Share Posted June 29, 2019 Sounds fine Just holding good pressure Oil type will make a difference also Link to comment Share on other sites More sharing options...
wile e coyote Posted June 29, 2019 Share Posted June 29, 2019 Make sure your using correct oil http://www.mkiv.co.uk/vbb/showthread.php?56684-FAQ-Oil-Fluid-Interval-Capacity-Steering-Brake-Coolant-Diff-Engine Link to comment Share on other sites More sharing options...
Sheefa Posted June 29, 2019 Share Posted June 29, 2019 How much you use and the oil level will also depend on whether you have any additional oil coolers. Mine is filled to the Max level or just over on cold start given I have two extra coolers fitted. Link to comment Share on other sites More sharing options...
