little num Posted June 27, 2019 Share Posted June 27, 2019 So decided to break my supra, so this add is for a full kit to fit in the mkiv supra, this kit contains 2 year old chaser box that's done 1 Silverstone track and 8 thousand miles if that. It's got the cradle same as the v160 style so no bodge shifter extension. Also has electronic speed sensor so your plug just plugs on. This gearbox is in perfect condition and is super smooth. Parts included are full prop - clutch master and slave both 2 years old. Pressure line - clutch pedal - 2 year old OS GIKEN double plate clutch with flywheel - flywheel bolts - manual gear surround but does have clips broken. All bolts and nuts that are needed for installation. Price is £3750 and will not drop. I can also include dash clocks that are TRD stainless style for extra £200. If you want pictures wattsapp me 07751150442 Link to comment Share on other sites More sharing options...
little num Posted July 9, 2019 Author Share Posted July 9, 2019 Price dropped to £3750, it's all out and ready to go. Link to comment Share on other sites More sharing options...
