Speedo and odometer problem
Ferlex
Hey guys, so I recently got my kmh to mph converter fixed and now my speedo is ready much higher mph than normal. It's about 15 mph off, I noticed that travelling at 85 mph gps speed shows on the speedo as 100. The odometer also goes up according to the 100mph on the speedo so I did a trip which was about 45 miles and I recorded that on the speedo it showed it put about 80 miles on there. Does anyone know how I could fix this? If it helps I have some faces on the speedo.
Indeed you need one that is setup for your rolling radius. The speed sensor (in the gearbox I think in our case) sends pulses which are turned into speed depending on the frequency. Obviously may vary depending on the vehicle/speed sensor.
I use a SpeedM8 which was setup by the maker for a MkIV on standard wheels and reads pretty much bob on with the GPS. It over reads when using the Lexus 18's.
I believe some limiters had some adjustment where you could go out with a GPS and fine tune?
