Ferlex Posted June 24, 2019 Share Posted June 24, 2019 Hey guys, so I recently got my kmh to mph converter fixed and now my speedo is ready much higher mph than normal. It's about 15 mph off, I noticed that travelling at 85 mph gps speed shows on the speedo as 100. The odometer also goes up according to the 100mph on the speedo so I did a trip which was about 45 miles and I recorded that on the speedo it showed it put about 80 miles on there. Does anyone know how I could fix this? If it helps I have some faces on the speedo. Link to comment Share on other sites More sharing options...
Ferlex Posted June 26, 2019 Author Share Posted June 26, 2019 Anyone? Link to comment Share on other sites More sharing options...
rider Posted June 26, 2019 Share Posted June 26, 2019 There is a section on the Torque GT site where they talk about and retail the speed converters and say that you need to ensure you have the vehicle specific converter. Maybe you have a converter for another vehicle fitted? Link to comment Share on other sites More sharing options...
Pete Posted June 26, 2019 Share Posted June 26, 2019 Indeed you need one that is setup for your rolling radius. The speed sensor (in the gearbox I think in our case) sends pulses which are turned into speed depending on the frequency. Obviously may vary depending on the vehicle/speed sensor. I use a SpeedM8 which was setup by the maker for a MkIV on standard wheels and reads pretty much bob on with the GPS. It over reads when using the Lexus 18's. I believe some limiters had some adjustment where you could go out with a GPS and fine tune? Link to comment Share on other sites More sharing options...
