Are adjustable cam gears still a thing
Swampy442
Unless you can adjust each cam separately then no you cannot tune it with todays ecu’s. Cam gears are there to set the correct degree offset from tdc for the cams. They come with a specific offset and you need to degree your cams to your engine to get the best performance out of them. When you buy aftermarket cams they tell you how many degrees they want to be (either before tdc or after). Stock cams are made to work best with the stock gears, Or so i am lead to believe.
