Houstie999 Posted June 10, 2019 Share Posted June 10, 2019 So Iv found someone to refurbish my turbos but he needs to know the exact turbos my car is running I’m hoping for at Japanese import, 1996, TT manual 6 speed there’s only one option for turbos Can anyone tell me what turbos are on my car? Thanks for your time Quote Link to comment Share on other sites More sharing options...
Shane Posted June 10, 2019 Share Posted June 10, 2019 Manufacturer Toyota (Hitachi) Type CT-20 (PN: 17201-46020 (Front), 17208-46020 (Rear) Turbine size (Outlet diameter) 48mm Turbine size (Inlet diameter) 59.8mm Turbine blade count 10 Turbine material Ceramic Turbine housing Inlet (ID) 36mm Turbine housing Outlet (ID) 50.1mm Turbine shaft Diameter 10mm Turbine housing A/R .35 Compressor size (Inlet diameter) 37mm Compressor size (Outlet diameter) 62mm Compressor blade count 10 Compressor material Aluminium Compressor housing Inlet (ID) 49.8mm Compressor housing Outlet (ID) 32.4mm Compressor housing A/R .36 *Wastegate size (ID) 26mm Actuator spring rate 10 psi Bearing ID 10.05mm Bearing OD 15.9mm Bearing width 9mm Bearing material Bronze Bearing oiling holes (per bearing) 6 Think this is what you will have but can't accept any responsibility if yours is different. I took this data from another site years ago when I was talking to Nerings about replacement cores. Sadly despite an encouraging start they never came through. Quote Link to comment Share on other sites More sharing options...
