Door inner seal
bonus_2000
You need something like Loctite Weatherstrip or 3M Rubber Weatherstrip. The 3M is generally regarded as the superior product and there is a Shrewsbury eBay seller in the UK (not me btw). Both cost around £16 for a small tube but a small tube would pretty much do a whole car as its only a small bead required. Have something ready to rest against the seal where it goes around corners until the sealant has time to set otherwise the seals can lift or even look to cut a corner in preference to going neatly around the corner.
