Sheefa Posted August 4, 2019 Share Posted August 4, 2019 Id like twins for a bit of head room, just in case. And its a street car, so 550/600, reliability is the key with useable power You can also have a backup pump just in case any other line debris makes a return to life and decides to mate with your fuel pump! I guess the Link could power and flow both pumps at say 50% for safety and ramp up depending on boost? You going to get a fuel flex sensor in there matey and run some E85? Mad not too for an extra buzz :-0 Looks aces mate very good progress. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted August 4, 2019 Author Share Posted August 4, 2019 I haven't thought about flex fuel, I dont think its necessary for the power Im running and the usage of the car, but worth considering... Re pumps Ill have to ask who's mapping it what they recommend Quote Link to comment Share on other sites More sharing options...
Chingy Posted August 5, 2019 Share Posted August 5, 2019 Nice work Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted August 13, 2019 Author Share Posted August 13, 2019 Nice work Cheers Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted August 13, 2019 Author Share Posted August 13, 2019 Need a favour, can someone post a picture of their ABS pump please? The car had a line lock fitted and the brake lines are all jacked up so I need to see what I need to replace/how it all fits together Quote Link to comment Share on other sites More sharing options...
The Raven Posted August 13, 2019 Share Posted August 13, 2019 Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted August 13, 2019 Author Share Posted August 13, 2019 Many thanks for that, Ill check what I have, pretty sure I need a brake line or 2 Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted September 18, 2019 Author Share Posted September 18, 2019 (edited) Does anyone know what bracket is missing here, or has a pic? Supporting the dip stick and diagnostic port Edited September 18, 2019 by Swampy442 (see edit history) Quote Link to comment Share on other sites More sharing options...
Burna Posted September 18, 2019 Share Posted September 18, 2019 Things Craig likes, new bolts, new arms, new hardware, new suspension adjusting bolts, new brake lines. https://jza80.mkivsupra.net/imports/2019/06/99.jpg Some aerotop specific scaffolding? https://jza80.mkivsupra.net/imports/2019/06/100.jpg https://jza80.mkivsupra.net/imports/2019/06/101.jpg Any idea what this is? Im assuming its an aerial amp, strange location for it https://jza80.mkivsupra.net/imports/2019/06/102.jpg Some Link plugin goodness also arrived, to power whatever turbo set up we choose https://jza80.mkivsupra.net/imports/2019/06/103.jpg If you need a set of LINK ECU covers then let me know, as I sell 3D printed ones, but you may not have seen them on facebook or ebay. They save you having to remove the covers from your stock ECU and therefore making it useless to sell on, being as they now command a pretty penny. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted September 18, 2019 Author Share Posted September 18, 2019 Nice work mate but I've got a few ECU's I can use for covers, and from what I've seen for Link covers they aren't 'realistically priced', not saying yours are. How much? Quote Link to comment Share on other sites More sharing options...
Burna Posted September 18, 2019 Share Posted September 18, 2019 Nice work mate but I've got a few ECU's I can use for covers, and from what I've seen for Link covers they aren't 'realistically priced', not saying yours are. How much? Fair enough mate. They are £120 a set + £10 shipping. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted September 26, 2019 Author Share Posted September 26, 2019 As above, any help identifying the missing bracket to support the dipstick? Also :- Lots going on but its nothing really worth photographing. Wired in some new knock sensors for the Link ECU, cleaned the gearbox up, stripped about 50 kgs of superfluous wiring out and tidied the rest of the wiring up. Fitted brake lines, got Hodge fuel hoses coming, washed the carpet, made bracketry for the front mount. Etc, etc you get the idea, niff naff. But... Engine ready to go And in the car! Thankfully I got the Supra gearbox mount with the car (Supra on top), as the Aristo one was a mile out. Discovered I need a new turbo oil feed, no dramas but a bit strange. Then again the engine does sit a fair way back compared to the Aristo Now its a steady reconnect, replacing hoses and stuff as I find them, and get a crash course in Link home tuning Quote Link to comment Share on other sites More sharing options...
Style Posted September 27, 2019 Share Posted September 27, 2019 Nice progress Bit of a random question but do your new fuel lines have a banjo style fitting for the fuel pump end or is it still just a 90deg bend? I got the lines a few years ago and was a bit naffed off that I couldn't get my cover back on again with the 90deg fitting sitting proud. I guess a banjo style fitting would sort that but not sure what their flow capabilities are like. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted September 27, 2019 Author Share Posted September 27, 2019 The stock fuel feed is a banjo fitting so should flow enough? The lines I think are standard AN fittings, John Hodge formerly of this parish made the kit, he's made lots in the past for many members, it fits under the stock cover. Quote Link to comment Share on other sites More sharing options...
Style Posted September 27, 2019 Share Posted September 27, 2019 The stock fuel feed is a banjo fitting so should flow enough? The lines I think are standard AN fittings, John Hodge formerly of this parish made the kit, he's made lots in the past for many members, it fits under the stock cover. Yeah I've got one of the kits as well and looks to just be standard AN fittings, but the 90 into the tank has quite a big radius on it. My one certainly doesn't fit under the cover and I know a few others who have said the same. It's also what's brought about the custom covers that some people are selling. I heard John was experimenting with the banjo style fitting but nothing seems to have come of it. Just wondered if he'd updated his design. Have you just gone for the stock sized kit he was selling or a higher powered one? Maybe that's the difference as I opted for the slightly beefier lines Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted September 27, 2019 Author Share Posted September 27, 2019 Its he stock sized kit, when it arrives I'll report back Quote Link to comment Share on other sites More sharing options...
Scooter Posted September 28, 2019 Share Posted September 28, 2019 As above, any help identifying the missing bracket to support the dipstick? It a black u bar that goes from the bottom of the block up to the intake manifold.....Intake brace. On the right of this photo. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted September 28, 2019 Author Share Posted September 28, 2019 Brilliant, cheers! Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted February 9, 2020 Author Share Posted February 9, 2020 Not really a lot of progress to report at the moment, lack of time and too many other projects. I have ran the fuel lines in, striped, refurbished, refitted the master cylinder and bled the clutch, reworked the turbo oil feed, sourced a pair of UK rear callipers, stripped, refurbished them and just eating to rebuild. Having a bit of a hassle with the Link software, but with help of a local mate I think its sorted. Just need to get a tuning cable (50 quid ffs). On the plus side, I did pick up a pair of 17" stock rear rims for 50 quid I was going to get them widened to go with the next stage of the project. But I might just follow the rest of the community price wise and sell them for 600 quid Quote Link to comment Share on other sites More sharing options...
Noz Posted February 10, 2020 Share Posted February 10, 2020 Lol I have a set of 16s! Was hoping I'd get 400 Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted April 9, 2021 Author Share Posted April 9, 2021 Can’t believe it’s been over a year since the last update!! I’ve got a job back home now, so been doing bits, just had a week off and made big progress! In fact it’s not that far from mapping. ive got it started and idling on the Link, only really a few details to wrap up! 1 Quote Link to comment Share on other sites More sharing options...
Noz Posted April 9, 2021 Share Posted April 9, 2021 Miss having a black one. Exciting times! Quote Link to comment Share on other sites More sharing options...
fastphil666 Posted April 12, 2021 Share Posted April 12, 2021 Been following your exploits on pistonheads, spied the supra in the background. Was wondering when we'd see an update. Good work. Quote Link to comment Share on other sites More sharing options...
