Replacement Coil packs??
ManwithSupra
I used the whiftbitz on my BPU, lasted about 30000kms, had slight cracks and developed a misfire. They were fine when they were new.
My originals had worse cracks and didn't misfire.
Replaced with a new set of OEM, like a different car.
With your power, OEM all the way.
I have a few new OE coils, I can part with one for £95. If interested PM me. You only need replace the one that has failed or is failing rather than swap out the lot. Coils tend to either work or not work. You could check the resistance of the other coils just to check they are in spec and similar (around 13k ohms from distant memory) just for peace of mind on the others.
Edited by rider (see edit history)
Do you have a part number for the denso coils?
I can Google it but be handy to know if there's a particular variant you could confirm was available and trusted.
I was unsure what to choose with my 600hp goal. Really glad people have asked this question.
