wastegates
eyefi
Quote: from eyefi on 10:04 pm on Feb. 10, 2002[br]regarding boost creep on decat jspec mkivs, has anyone fit an aftermarket wastegate?
The wastegate is built into the turbo housings (flapper type), not external. i have converted a car to parallel turbo action, and used the exhaust by pass valve as a second wastegate. You may be able to mill out the existing wastegate hole some more, even fabricate a bigger flap valve , and this should certainly help. The bigger exhaust A/R of the Uk and US spec turbos also fixes it.
