Rear passenger side inner arch
shervin_ice
  • 2 weeks later...
Are you referring to the wheel arch or the wheel housing panels?
If the arch its double skinned with the outer wheel housing panel spot welded onto the wing. If it's the wheel housing panel you are referring to all four of the inner and outer ones are discontinued with none remaining anywhere in the World. I looked around 2 years ago for those with the thought of buying in a few as spare parts as I have lots of storage room here and to sell them on in a few years time. Your only prospect to get one of these now is cut off a shell or donor/scrap car so probably best to contact the known Supra scrappers/recyclers or buy your own donor car and recoup the cost in scrap parts. Or you could get one fabricated, anything can be made from thin sheet steel.
