James. Posted May 12, 2019 Share Posted May 12, 2019 (edited) Im installing some custom aftermarket speedo plasma dials. The ones that fit over the originals. There’s only 2 wires from the new speedo lights 12v inverter, red positive and black negative. I’m thinking the best way would be to connect them to the dimmer switch wiring? Be good to know if anyone has fit these before. Edited May 12, 2019 by James. (see edit history) Quote Link to comment Share on other sites More sharing options...
The Raven Posted May 13, 2019 Share Posted May 13, 2019 Im installing some custom aftermarket speedo plasma dials. The ones that fit over the originals. There’s only 2 wires from the new speedo lights 12v inverter, red positive and black negative. I’m thinking the best way would be to connect them to the dimmer switch wiring? Be good to know if anyone has fit these before. Mine where wired into the dimmer Quote Link to comment Share on other sites More sharing options...
James. Posted May 13, 2019 Author Share Posted May 13, 2019 Mine where wired into the dimmer Sound, thought so I’ll do it that way. Quote Link to comment Share on other sites More sharing options...
James. Posted May 20, 2019 Author Share Posted May 20, 2019 Okay so I thought I could find some info online as to which wire is which on the dimmer but im struggling. There are only 3 wires green/orange, black/white and green/white. I understand you can test with a multimeter but I don’t usually get involved with this kind of thing so I don’t have one. It’s just knowing which one to get power from so they work with my headlights. If anyone can help would be appreciated. Quote Link to comment Share on other sites More sharing options...
