tayr Posted May 11, 2019 Share Posted May 11, 2019 Hi guys Picked up my TT6 yesterday which was imported Is it normal for the engine to rattle when turning it off? Literally for 2 seconds as the revs go to 0 Many thanks Taylor Link to comment Share on other sites More sharing options...
tayr Posted May 11, 2019 Author Share Posted May 11, 2019 (edited) Btw I do have a High idle. Just cleaned out the ICV but no difference Edit: idle now all good Edited May 11, 2019 by tayr (see edit history) Link to comment Share on other sites More sharing options...
Mike2JZ Posted May 11, 2019 Share Posted May 11, 2019 (edited) Usually the noise of your driveline coming to a stop when engine is turned off. Normal to hear on a TT6 Edit: You may also hear the IACV motors reset when engine is turned off. Sounds like a buzzing noise. This happens for a few seconds, so next time you start the car the IACV is able to give correct airflow into engine to allow start up & idle. Edited May 11, 2019 by Mike2JZ (see edit history) Link to comment Share on other sites More sharing options...
tayr Posted May 11, 2019 Author Share Posted May 11, 2019 Usually the noise of your driveline coming to a stop when engine is turned off. Normal to hear on a TT6 Edit: You may also hear the IACV motors reset when engine is turned off. Sounds like a buzzing noise. This happens for a few seconds, so next time you start the car the IACV is able to give correct airflow into engine to allow start up & idle. Thank you mate!! Link to comment Share on other sites More sharing options...
SteveC Posted May 11, 2019 Share Posted May 11, 2019 A dual mass flywheel can rattle a bit when switching off the ignition if the car has a good few miles on it. Mine did until I installed a new flywheel. Link to comment Share on other sites More sharing options...
Tyson Posted May 11, 2019 Share Posted May 11, 2019 A dual mass flywheel can rattle a bit when switching off the ignition if the car has a good few miles on it. Mine did until I installed a new flywheel. This would be my guess too as this is what mine does. Link to comment Share on other sites More sharing options...
Swampy442 Posted May 11, 2019 Share Posted May 11, 2019 Put your foot on the clutch before you turn off, see if its still there or not Link to comment Share on other sites More sharing options...
Scooter Posted May 12, 2019 Share Posted May 12, 2019 Put your foot on the clutch before you turn off, see if its still there or not This plus at rolling speed in first if you lift and push the clutch pedal up and down to the bite point you may feel some 'lash' 'chatter/clunking' which is quite common. Link to comment Share on other sites More sharing options...
keron Posted May 12, 2019 Share Posted May 12, 2019 As above Prob the dmf worn.... Link to comment Share on other sites More sharing options...
Tyson Posted May 12, 2019 Share Posted May 12, 2019 As above Prob the dmf worn.... You don’t have any new ones per chance do you ? Link to comment Share on other sites More sharing options...
