MK4 Clutch pedal assembly or complete manual conversion.
Mamos95
Good evening Supra Fam.
I am on the hunt for a W58 conversion including all bits to swap out my auto trans. Can anyone assist with helping me find a clutch pedal and all other bits i’ll require? Based near Wiltshire happy to travel.
Regards image
I have most of what is required for a manual conversion for sale.
- W58 MKIV remote shifter box (rebuilt with new bearings in 2016 and will be serviced and checked prior to sale)
- shifter (r154 so slightly taller but fits)
- 2JZ flywheel
- Transmission mount and crossmember (I’m waiting for a spare to be delivered at the moment).
- Front half of propshaft to suit MKIV
- RPS Max clutch with street disc (the most friendly and streetable 500+lbft clutch you’ll find!). It uses a factory Toyota friction disc for drivability too. Plenty of life left, has around 10k miles on it.
- OEM flywheel bolts (used and would recommend replacement)
- Clutch bolts (used and would recommend replacement)
- OEM Toyota release bearing - less than 5K miles
- OEM slave cylinder
- OEM master to slave hard line
£1200, but open to sensible offers.
