Low level clutch fluid sensor
Noz
Going to install one. My hydraulic release bearing failed so my fluid ran out without me knowing. Until it was empty.
I can install my own sensor. I've found a non contact external fluid level sensor for through plastic measurements.
But is there anything more oem available? Curious if any supra ever had this function.
Brake fluid also.
Brake fluid also.
Well it already has a brake one so you could just tap into that for a stand alone one rather than the master warning light.
Could you not use the same one for the clutch fluid ? They are both hydraulic systems so should work the same ?
I can’t see that there is any Toyota with a clutch fluid level sensor from the factory.
