Na ignition coil
blythmrk
NA Ignition coil (2jz ge) with bracket and noise condenser.
It does have a little bit of white over spray on it but nothing major!
[ATTACH=CONFIG]231585[/ATTACH]
[ATTACH=CONFIG]231586[/ATTACH]
[ATTACH=CONFIG]231587[/ATTACH]
[ATTACH=CONFIG]231588[/ATTACH]
£20 delivered in the Uk or collection welcome from near Sheffield.
This is something I don’t need, so may as well let somebody else have use of this👍
  • 1 month later...
Have you tested it to see if it falls within the resistance specs in the TSRM?
Only reason I ask is that someone was after one on the Facebook groups but he wanted pics of the multimeter readings in line with the spec before buying. They can get a bit tired over the years and fall out of spec which causes spark blowout on NA-T cars. So you could have a buyer there :)
