Mark C Posted April 10, 2019 Share Posted April 10, 2019 Hi All, I have a slight oil leak on the right hand side hex bolt on the top of the oil filter housing. Picked up a 14mm hex key today (think thats the right size) and am going to tighten up later. Is this just a blanking nut on the NA? , should it be flush or just as tight as i can get it. Anyone know if there is a gasket/seal under the screw that may need replacing? Any advice appreciated Thanks, Mark. Quote Link to comment Share on other sites More sharing options...
