Is it plug and play ? Automatic transmission A340 -A343
SupraTTBPU
If you have a J-Spec TT box, then the swap is plug-and-play. If you have a J-Spec NA box, then it is not plug and play, as the NA box has a 4-pin connector for the valve body and that TT box has a 8-pin connector. different flange for the propshaft (you will need a full TT auto prop) and the N/A ECU will not be able to control it, due to lack of line pressure cable and the aforementioned connector difference for the valve body.
This post here should give you a bit of an idea about the differences: http://www.mkivsupra.net/vbb/group.php?discussionid=153&do=discuss
