Error Code 63, automatic transmission bad shifting
SupraTTBPU
Hello and good evening :)
For a long time I have now the problem with the Error code 63.
Defective no2 shift solenoid or shirt circuit severed wire harness or shirt circuit.
I checked my SLD, Oil ... and everything is fine.
Before i check the shift solenoids inside the tranny, where should i check if it is just a wire problem...
Do you know which pin it would be to check at the ecu ?
Or any other tips and ideas to check before i open the tranny...
Thank you in advance and have a nice weekend
Regards
PS: Where can I found "new" shift solenoids for my Supra ...
Edited by SupraTTBPU (see edit history)
